- Nov 14, 2016
- 3,351
It may be worth your time to see if it is possible to mount a new type of spindle mount on your lathe. Those Dro-pro lathes have a very basic and inconvenient spindle mount (a flange with bolts). I'm not familiar with the aftermarket for these, but surely there is an improved aftermarket spindle mounting available. If nothing else it seems like making a bolt on threaded spindle would be a better option.
This mounting system will continue to be a problem for you with any chucks you use with this lathe. In my opinion that would be a very worthwhile upgrade that you will appreciate for years to come. I'm not familiar enough with these lathes to know if you could adapt the quick release mount from the PM 1022/1030 or the threaded spindle from the Grizzly G602 but that might be an option as it appears they are just variants of the same basic lathe. It might be worth calling Dropros to see if they are aware of any better options.
