- Jan 9, 2020
- 18
You're a good guy. I hope to do the same for my son some day. Your insight is valuable and I agree with everything you've said. But, there's still that cost problem... the upfront one.Totally understand the cost issues. The reason I suggested the PM1340 is because it is ideal for what you have in mind. The spindle bore will take your 37mm stock easily and it is a Taiwanese lathe with a good build. It has all the features a good engine lathe has but in a smaller package and at a steal of a cost for what it is. Another option is the 1236T; it is also worth a look.
Believe it or not, I'm actually looking at this from a cost standpoint. If I was going to do prototype work or small production work then I would want to start off with a lathe that can do that kind of work. It will NOT pay to buy a small hobby class lathe and then trade up to a 1340; it will cost you more to do it that way. I would also opt for a new lathe that will work right out of the gate instead of having to deal with wear and functionality issues.
You should also understand that fully tooling up a lathe will cost you nearly as much money as the lathe does, if not more. This is less of a concern if you can recover those costs by selling what the lathe produces so if your marketing survey looks good and you think you can make a go of it then buying a lathe like this might just be the best bet for you.
Perhaps you might discuss this with some of your family members who would invest some money in your dreams. If my son came to me with this idea, I would buy the lathe for him and tell him to go for it. Something to think about, maybe?
Good luck to you with this.
I'm still soaking up all the advice and exploring options. Hopefully I can find an affordable solution.
Thanks again for the quality advice.
