- Apr 8, 2013
- 2,021
I had a friend come to me with an emergency job. He had to put a thumb on an excavator because a job was being held up. He had his fab guy torch off a mount off an old junk machine but discovered the bosses were bored for a 1.5" pin but the new thumb used a 1.75" pin. He brought it to me to get bored out. This was pushing the limits of my HF round column mill but I am his last resort. The part was too big to bore both bosses from the same setup so I had to bore one hole and then flip the whole setup around and bore the other one. I was nervous about getting the new enlarged bores to line up with each other. The bosses had been ground on and welded on so there was no surface to indicate off of. I figured the angle plate would take care of the X direction but the Y was flopping in the breeze. I finally tried taking a straight boring bar, stuck it thru both bosses against the Y direction and held it with a bungee cord. Then I indicated it vertically until the holes were in in alignment. Next I took my shiny new coax indicator out of the box and stuck in a collet. I love that thing. Once I figured out what probe to use I had had the needle barely trembling in about a minute. Best $80 I ever spent. I bored the two holes from separate setups and said my prayers. There was no way to test the alignment until the job was all done. The pin went in like it was sliding into a jar of honey. Murphy must have called in sick!
