- Oct 30, 2012
- 960
My theory on the fixture plate is why drill ALL the holes ahead of time? Drilling and tapping hundreds of holes is a lot of unnecessary labor up front when most will go unused. I simply put a zero locating dowel in the center x,y so to add more holes I just need to drop it on the table, the dowels on the feet fit snug in t slots so just indicate center pin in table and drill new holes as req.
I don't tap the holes. Instead I use F drill .257 and c-bore for standard press fit type bushings. 1/2"od x 1/4"id x 1/2"h. Bushings are a slip fit to the c-bores and serve to elevate the stock off the plate. Very inexpensive and I have about 8-10 but usually 4 is plenty to hold the work. Reason being is I make pattern cores from HDPE and modeling board and all the sides get tapered and machined down to the bottom. Rather than screw down to a wood or other spoil board I just elevate on the spacers.
If 1/4-20 is too large a thread to tap in the part I have used 10-24/32 screws with washers. The spacers still work the same located in the c-bores.
Now I know there are lots if ya but's about this way of doing it.
Its not good for every situation. Not the most rigid/super accurate if re-locating the part becomes necessary.
I cut stuff all in one and done.
For hogging steel its not the way
True, tapped holes in the bottom of the part may not always be acceptable.
Being raised up off the table allows me to take it on and off without messing with my vise.
If need be I can make taller standoff feet or space them farther or closer together.
It sacrifices about 5" of Z height.
If I need to clamp from the top, the .257 holes are conveniently the tap drill for 5/16-18.
The only real purpose for the c-bores is to keep the spacers aligned with the tapped holes in the part. Lot less fiddling with my 6" scale fishing underneath moving them around to get them in line.
Raised up and thru holes I never need to mess with clearing packed chips out of holes or using a jillion setscrews which still get chip packed in the hexes.
I don't wear out/gall/strip threads in aluminum plate.
Much less labor than threading all them holes.
My table stays mint, no rust between plate etc since the table comes off when finished.
Thats my story and I'm sticking with it....
