Huge code violation!
First thing is put a 30 amp breaker on that wire YESTERDAY!
If something happens and that is found, heap of trouble.
Next, measure the conduit size and try to remember how many bends and where they are.
Call your local building department and ask them the largest size wire that can fit inside that conduit for the required amount of conductors.
Required amount...?
Normal would be 4, L1, L2 Neutral and safety ground.
But due to distance and other factors you may be able to use a smaller safety ground and or use a ground rod at the shop.
Larger wire is very little more money now so largest you can pull.
Code limits conduit fill by diameter, bends and sweeps may reduce it further, your electrician may advise there.
Sent from my SAMSUNG-SM-G930A using Tapatalk
Required amount...?
