I posted this in the Precision Mathews section but thought it would be best to also post it here for more exposure. Here's what I posted earlier today.
After reloading the D2NC software I'm still having the same problem. What's interesting is I have a duplicate copy of D2NC loaded on my other laptop and loading the same .dxf file it works fine. This leads me to believe the process I'm using is correct.
Here's what I'm doing. I'm opening D2NC from within Mach 3 and selecting my .dxf file. I select the origin then click the Offset button. I'm doing an internal hole so I click on the circle in the drawing section, select In/Right, input the tool diameter and click Offset. So far good. Next I click on the Path button, again select the circle in the drawing section, and click Contour. The Contour screen appears and I select Local Shape and then None. I select the circle in the drawing section then press the Move Current Selection to Local Shape button. When I do this the Close, Add Only and Add and Close buttons at the bottom of the screen disappear. I've moved the cursor around to see if the function is still available. No luck. My questions are:
Is it a D2NC issue?
Is it a Mach 3 issue?
Is it me?
I'd like to get my machine running but these hardware and software problems are keeping me from doing so.
Tom S
