~Re: CNC decision paralysis - Probably Tormach
So I've dug into this agian, for the N[SUP]th[/SUP] time. I located a reasonably priced Haas TM-1 and Mini Mill. They are both at the top of my budget. But I could swing the machine purchase. However, here's my situation. I live in a low/non-industrial area, so most of these machines are 1500-2000 miles away. So I'd need to add significant freight costs. My garage doors are 7' and ceiling is 8'. So the Z would need to be removed or modified to fit under the door and then reassembled, for many of these machines. Then the ceiling would need a little drywall work to fit the Z height.
I moved my Bridgeport inside a large Penske truck with a lift gate. This mill was 2500 lbs and was at the limit of the lift gate. These machines (at least the TM1) are significantly more than this. So that means the rental of a large fork truck (and the associated delivery and pick-up charges) or I'd need to hire riggers to unload and install the machine.
Then... None of the machines I found came with any tooling. So I'd need to purchase this. None of the machines came with CAM software (nor would I expect them to), so I'd need to purchase this also. So now the machines that fit into my budget, now exceed my budget by a factor of about 2x.
I also looked at older CNC machines for retrofit. I've always liked the Centroid units. These are available in ready-to-install prewired configurations with or without servos. This gets the old CNC machines in line with my budget. But again, Rigging, tooling and CAM software all some into play. So now these $5k obsolete CNC units, are over budget by about 1.2-1.5x.
I definitely see the niche that the PM, Tormach, IH and other machines fill. They may not be as capable, rigid, or fast as their big brothers, but one can get into a well tooled machine, with software, delivery and installation for a relatively small comparative budget.
This may not be all encompassing, as many great deals come along and if one is willing to take more risk, or resides nearer to larger machines, the options open a lot. For me, my situation and my location here's what I found.
For a budget of 0~$5K, a small retrofit is probably in order - lots of work, lots of tinkering
For a budget of $5k~$20K, a PM, Tormach, IH or similar machine may be the best choice
For a budget above $20k, a full size CNC machine options open (depending on a lot of other factors, of course).
Again, this may not fit everyone's situation, but seems to fit mine. I had a lot of PM's with many folks here, all of which were exceedingly friendly and helpful. So thanks to all for assisting my research.
