• Welcome back Guest! Did you know you can mentor other members here at H-M? If not, please check out our Relaunch of Hobby Machinist Mentoring Program!
  • In order for the Member Map to work properly, you must allow Google services AND Hobby Machinist to know your location. These settings are found in your browser of choice and in your Hobby Machinist profile.
Winner Clock
  • Thread starter Thread starter WMello
  • Start date Start date
Status
Not open for further replies.
Hi David,
Yes, everything with a curve in it was made in the CNC
The white stuff is still coming down; 25 inches so far.
Not usual around here (Could this at least be on workdays....)
Wagner
Pallet Frame
Wagner, once you have cut out the shapes, how do you break all the sharp corners / edges?
Still looking awesome.
David
Hi David
File and a lot of sandpaper. 220, 320, 500, 600 on all faces. Then 500/600 on the edges.
This parts (and most off the others) will be polished and coated with lacquer lather.
At least, this is the plan.
Wagner
Awesome Wagner!. Were you adjusting the beat during the movie? At one point it sounded like it was slightly out of beat and then seemed better.
David
Fiddling with all the adjustments.
Surprised on how ease was to make it run for the first time.
The beat is easily adjusted by the two screws on the fork. The drop is another story... and to make the teeth fall on the dead face of the pallets took a while.
Needs more swing also.
Wagner
Status
