- May 2, 2011
- 835
Excellent!! from what I saw on the pics you made a very neat job, two layers of shrink tube was a good idea as well! I also share your hatred of digital test equipment.You can test the megger by connecting a resistor across the leads, or connecting them together for a brief moment, it should go to zero. There is no return spring on megger meters, they take up their own random position untill you press the button or wind the handle. With the windey meggers we used a 1megohm test resistor, and a short circuit test (leads clipped together) to check the zero resistance end of the meter. The windey type wee megger is virtually bulletproof, everything that came afterwards is unfortunately fragile!
Phil
Phil
