- Sep 15, 2017
- 55
As I said in the initial thread..the lathe is in the middle of the garage and I have no inclination to move it further. I actually like it there, especially as I clean and inspect because I have full access (give or take a messy pile of 'stuff'). I ran 20 amp, 220 power to the VFD yesterday. I have single phase power to the vfd, I have 3 phase power coming out of the vfd, 3 phase power at the lathe but the VFD is not powering up. I have power through the VFD but no LEDs and no controls. I ordered a new VFD and I moved on to cleaning after that.
I took the tail stock off, removed the ram, hand wheel, knobs and base. The key for the ram is broken. From what I have read, that is common. There are a lot crevices with years of crud and metal chips but mineral spirits and a wire brush are quickly revealing a pretty decent surface with good paint. I need to remove some surface rust from the handwheel. I have some stubborn spots in the cavity around the cam shaft that needs further attention. I will get it lubed and put back together in the morning (before I forget where everything goes). I took the panels off the headstock pedestal and they cleaned up nice as well. It is nice to see paint under all of the grime.
I'm a little concerned about the headstock spindle. Turning it by hand, it turns freely for 1/2 to 3/4 revolutions and then it grabs and releases again. Thinking about it, I will check the belts and pullys. The lathe has been sitting up for 5 years so the belts may be stiff and complaining about moving around. I'm the same way when I get up in the morning.
