- Mar 26, 2018
- 8,707
I am posting this because I am sort of new to machining, and this is the first "thinking outside the box" repair I have done on my step pulley Bridgeport.
A friend and co-worker is rebuilding a 1970 Ford F-100, for his 15 year old son. It has the 360 CID engine. One of the exhaust manifold bolts was busted off in the cylinder head.
I volunteered my services to give it a try.
Joel brought the head in the shop early Saturday morning. No fancy angles required, the head is symmetrical or parallel from side to side.
The 3/8 hole is pretty buggered up from previous repair attempts. I grabbed a 3/8 center cutting 4 flute carbide end mill and carefully got everything centered and locked the table.
Joel carefully went at it, there was some chips, some crunching and as we pulled up the quill, blew some air and solvent in the hole, the "Easy-Out" came flying out and landed on my SB lathe chip pan. From that point we cleaned up the rest of the hole.
Then he brought out the drill bit. Yep we need to drill out the hole to install a Helicoil.
I looked at the head, grabbed my R8 keyless drill chuck and wondered if I had enough working room.
Down we went with the table. The chuck is large.
I had no idea the table went down that far. I have never used it way down there. So, we pulled up a couple of stools, (just kidding).
We drilled the hole and inserted the helicoil.
What a great feeling to help out my friend. He was thrilled. He volunteered to buy me another end mill.
He sent me a pic that afternoon and showed the head installed with the manifold bolted on.
I love this old Iron.
Why do they call them, "Easy-Outs?"
