- Jun 10, 2019
- 537
I found your thread/watched your vids after posting an unrelated thread in this Rockwell forum. I liked the "rebuild" series - neat mill! Love to have one in my garage - its on the list.
For tapping or threading SS, I learned the hard way too. You definitely need quality taps/dies. The cheapos are garbage compared to quality brands. Buy once cry once. A long taper (starter tap) is a must. A 2- or 3- flute tap (vs. 4 flute) can also help.
What size drill were you using? On harder materials you can go with a smaller thread engagement (which means larger drill size). For 1/4-20 at the usual 75% thread you'd be using a #7 index. But for SS you could go as low as 60% thread and be plenty strong. But say 65%: you'd be at a #5 index. This little bit of extra size helps. (I should note: i'm just a hobbyist, but this is straight forward info from machinery handbooks).
One other thing I found useful on SS is a mix of tapping fluid and anti-seize. Picked this up from a vid on youtube and seemed to work better than straight cutting fluid for me.
