Made a lens for a pressure gauge out of 1.5 mm polycarb cut 3 x 3 square to be screwed to a bit of planed inch thick wood through the centre of which I put a counter sunk coach bolt , added half a dozen nuts and put it on the lathes face plate then trued it up before attaching the predrilled poly carb square with mushroom head wood screws.. across the whole of the square I used double side sticky tape to hold the lens in place when it separated then turned the disc from along the bed with a fine ground tool tip to just over size of the bezel including the lip . Made my own cups & a plunger on the lathe and then inserted the lens using the drill press table , cup & plunger to cup it .
