Clausing 5914 VFD
Some additional information about the motor mount plate...
Motor mounting plate used is 10"W x 8"D x 1/2" Thick.
It sticks out from the cabinet rail surface 2-1/2"
The front motor mounting screws are located 1" from the front of the plate, but you should check your motor geomtry on this.
Original motor brackets are redrilled so the captive nut plates can be reused and positioned so they end up roughly centered over slots in the mouting rail.
The motor mount and bracket mounting bolts go into threaded holes in the plate.
Some of the bolts need to be cut so they do not protrude and interfere with the brackets.
