So I mounted the threaded rod and bushing back in the lathe... Which is in the ER 25 chuck . I should have marked the position before I took it out. The collet hasn’t been disturbed, but it’s never good when anything gets removed from a three jaw and then reinstalled.
Anyway, I checked for out of round and was out around 2 thousands. I don’t think its going to affect anything adversely. If I had to do it over again, I would have used my 4-jaw chuck.
machined outer diameter to0.6240 and then the outer end a diameter of 0.5955” for a length of 0.8445
FWIW, the end which attaches to the dial housing doesn’t contact to small washer on the housing. The gear is a length of 0.8495. And the gear contacts the small stainless washer. I made a small Delrin washer about 0.025“ thick to replace the stainless washer which is 0.005”
I always had some slop in the dial which I could not remover through adjustments. I’m hoping the extra 0.020” takes this slack up.
I also made a test bushing the same diameter as the dial shaft. This shaft is 0.43730”
Of course, my test bushing is really close but no... it’s not .43730”. Me and my Clausing shoot for within a thousandth.
I bored the bushing to specs and checked it with my test shaft.
It did make that popping noise when I forced it in and then pulled it out.
