Clausing 5439 Restore Pictures
I'm using Rustoleum. I used the Dark Grey spray can primer/paint on all of the accessories not thinking ahead enough to check that is was available in a quart so I could paint the base, chip pan and ways. I ended up adding some black to the quart can of grey to get the base color, a bit too dark for a match but good enough for a lathe.
Hi
Did you spray all of it, or use a brush with the paint in the quart can.
Hi
I sprayed everything except the ways, it was easier to brush that than tape it all up and it also has a lot of areas that are hard to reach with spray.
Looks good hope you have lots of chips flying soon. Gotto love something like this to do so much for them . The machines I mean.
Slow progress due to other projects and some issues I ran into with the motor and pulleys. Moving along with the addition of a TECO VFD and new 3 phase motor. SAM_0874.JPG SAM_0875.JPG
