- Nov 9, 2018
- 377
I looked at the first picture of your bed and yeah... it’s rough. But don’t get discouraged. My first semi-real lathe was a 90 y/o SB model C with a bed twice as bad as the way your bed looks. Th apron crank was trashed. Anyway after tweeking and replacing the apron with an EBay apron....that little 9” SB is a surprisingly good lathe. It’s not perfect, but can make very nice parts.
Your Clausing will be much more ridgid than a South Bend 9”
I’d Concentrate on the cross-slide and compound. Make sure the lathe is leveled. Ignore the cosmetics of the bed for now. Unless of course you’re building stuff for NASA.
PS.... I’d use mineral spirits or diesel fuel. In my opinion...Coleman fuel is too volatile....too dangerous to use around a shop. I had a friend who used gasoline to clean a wood floor in his utility room. Long story short is that the water heater ignited everything and he was burned and scarred from head to toe. Stuff happens. No need to tempt fate.
Thanks, I’m now working on getting the headstock back together to get a good evaluation of the spindle. Then I’m going to level the bed and see how it cuts. First things I need to make are new bushings for the back gear, and a new cross slide nut.
Yeah, I’d never use Coleman fuel, it’s just WAY too volatile. I’m using a mix of spray on engine degreaser to dislodge the grease, and heated water based HF degreaser to scrub it away. When I get a parts washer, I might switch to the petroleum based parts cleaner at Tractor supply, I hear it works well, and has a very high flash point so it’s designed to be safe as possible for a hydrocarbon.
If everything else checks out OK, I might take the bed up to Milwaukee to get it ground and then scrape the cross slide, head and tail stocks to the ground bed.
