- Dec 20, 2012
- 9,422
Emilio, if I was to make that adapter I would bore it instead of ream it. With a sharp solid Micro 100 carbide boring bar, hitting a half-thou should not be a major issue. You would have straight walls, a clean flat bottom and a very good finish as well. Even if you did use a reamer, you would need to bore the hole straight first so why not just bore it?
I would opt for 6-32 set screws - more than enough wall thickness to obtain adequate strength for that screw diameter. The only issue is cleaning up the burrs in the bore after drilling and tapping so I would rough out the bore, drill and tap the holes, then indicate the work piece in the 4 jaw and bring the bore to final size. If you work carefully, this should be a simple project.
