- Nov 23, 2014
- 2,642
I have a similar Clausing (5418). Mine has a step pulley and no taper attachment, other than that it's the same lathe. As mentioned above, 2 1/4" x 8 tpi threaded spindle so care is needed when going into reverse. Also have a Grizzly G0709 14" x 40" lathe or a big brother to your 12 x 36.
I prefer the feel of the Clausing to my Grizzly. The carriage and compound move smoother.
If I had to chose between the Grizzly and Clausing, I'd take my Grizzly. No worries of spinning off the chuck with the D1-5 spindle. The gear head is nice for speed changes as my Clausing requires deep knee bends to change speeds (one you're looking at as variable speed). My model has a universal gear box, so turn one knob to switch between English and Metric threads. You'll probably need to swap around some change gears to flip between E/M with the 12 x 36, but you can do it. Clausing had a metric change gear kit, but they are extremely hard to find.
Bruce
p.s. If you have room, maybe buy both?
Bruce
