I havent used Lube finder, but they now on the radar for the next time I need some.
I use flood coolant on my Colchester Lathe, it’s probably because I’m a newby to all this, but I found that despite advise form Sandvic etc, that using it extended the life of carbide cutters considerably. However, I’m always concerned about cleaning down the lathe meticulously in case the coolant causes rust. With the mill, I’m concerned that coolant will get under the vice and may cause rust.....is this a justified fear? and if so, apart from using Metalguard and wayoil is there anything else I can do to project the table from it?
