- Nov 25, 2015
- 9,421
so I noticed that my can of Gumout carb/choke cleaner is a mixture of acetone and toluene. For some reason this works better at welding plastic than just acetone... Was cleaning my tractor with it for getting to the governor spring that broke. Ran out, before I realized I had one more can in the basement for welding plastic and cleaning. Now not wanting to buy a ton of cans (cheap), I thought why not mix my own. I have one of the pressurized vessels for dispensing. But then toluene is no longer avail at the big box stores, and when looking elsewhere appears to be prohibitively expensive.
I see xylene is available. The sds for gumout shows
so I know the approx mix.. I'm hoping someone here can answer, if toluene can be replaced by xylene, and will I be able to weld ABS plastic still? I ask because acetone alone doesn't seem to weld it , but this mixture seems to work. I know the CO2 is for propellant.
@pontiac428
@pontiac428
