- Feb 17, 2013
- 4,417
If it was ever repainted, for sure it wasn't recently, and definitely not a "lipstick on a pig" job for the sake of a quick sale. Both photos show areas where the paint job has worn away or been chipped off. I'll go +1 on others' comments and suggestions. Jet has a good reputation for machinery, though IMHO they do list for inordinately high prices.I am trying to figure out if it has been repainted. If they did, it was a decent job. Hard to tell in pictures.
An examination of the table surface will let you know if it's been abused, or used by indifferent jerks. Then do as careful an examination of the gib surfaces as you can. Also give the table a "shake" test, to check for worn or misadjusted gibs. You can check for spindle smoothness by manually moving the belts. And -worst case scenario- if the motor is shot, it shouldn't be too expensive to replace it. Maybe bring along a multimeter, to check the motor windings.
Best of luck! If that mill is what it appears to be, you'll have a great deal. Also ask about how much tooling might be included!
