they can be checked in anything that rotates.I have some Harbor Freight drill bits that may not be straight. I'm trying to salvage them for drilling soft materials. I don't have a granite surface plate. Can the bits be checked in a lathe or mill?
I'm not going to attempt to straighten them, just cull them.they can be checked in anything that rotates.
the question is how are you going to straighten them?
You will find that you can't indicate them. So it will have to be a visual.
Just say no to Chinese crap!
I have found many drills at the cheaper end of the spectrum that are quite straight, but the central axis of the flutes is not the central axis of the drill itself.What makes you think they're not straight? Roll them on a flat table or counter-top, you'll see it if they are bent. A drill that cuts an oversize hole is more likely to have a bad grind on the point. Easy to fix. And always remember, a drill is not a precision cutting tool.
