Check Out This Bevel
9 microns equals .00035. I tried planing balsa, best I could do was. .0035 to .005, not consistent. Must need a better wood.
For those kinds of shavings balsa will not do. You need a tighter grained wood, such as sugar maple.
I've had good luck removing under .001" shavings from maple and pine with a standard Stanley No3 or a Dunlap N05 "fore" plane. Keep the sole waxed and your iron sharp!
Japanese hand planes use no adjusting screws, the iron is all set with small hammers and taps. Tap the iron to advance it, tap the heel of the plane to retract it.
I was amazed at the planing competition, not just the work but how many onlookers there were.
Do most Japanese hand tools cut on the pull stroke rather than the westerm method of cutting on the push stroke?
