I'm fascinated and impressed with what you've been able to accomplish so far. This is a lot of top speed operation, has there been any noticeable heating in the motor or spindle?
It should be noted that I'm learning on the job here. The lesson for last night was how large a role temperatures play on this game. The attached picture shows the layout of measurements right after grinding (black), and after sitting for over an hour (blue).
The other thing I'm learning is that I need to switch over to the indicator to map out the table more often. I'm thinking I may have already done more grinding than necessary if I had been more methodical about measuring before cutting.
This is a great lesson/example of how higher degrees of precision multiply the difficulty. Without higher precision equipment, hitting .0001 is not just 10x harder than hitting .001.
I'm thinking this might have gone better if I had used a conical grinding wheel. I think there is some flex in this wheel.
Cooter, I was using some water based cutting oil initially, but it mixed with the grinding dust to form a paste that clogged up the disk. In fact, another lesson learned last night was to clean the disk with some degreaser periodically. When it clogs, it just pushes around, rubbing the top, leaving a mess of grind marks. 5 minutes of scrubbing the face with deagreaser and a tooth brush, and it cuts to a mirror finish.
Perhaps plugging the drains and filling the t-slots with water would help to absorb the heat from the metal without actually wetting the grinding disc.
