- Oct 16, 2014
- 318
Couple things if you go the insert route. The bullet is going to have a big jump before it gets to the rifling, maybe this is not a concern just wanted to bring it up.
Never seemed to matter to competition shooters, but it might this time. Now, of course, these were many years ago when the military competitions meant you had to use military caliber. So when the .30-06 went away, it had to be shot in .308. So that meant shoot a Garand with an adapter -- because a Garand with a .308 barrel is not a Garand -- or get rid of it for an M14.... which would invariably bring up yet another pointless debate about what's better than what.
You need to be careful that the insert does not come out when firing the rifle, this would create an excessive headspace situation, dangerous if the rifle was fire like this.
Has this ever happened ever in the history of these adapters, ever? Because I've only heard of them being removed with a broken case extractor. These operate nicely in semi-auto Garands, so I'd be very surprised if the comparatively gentle rigors of bolt action were to even jar one loose, let alone suddenly come out.
If you have some meat on the barrel shank I would cut off enough to clean out the 30-06 chamber with the 308 reamer. reset the headspace and redo the tennon as needed
Sure, probably the second-safest route, but also the route of most trouble and from which there is no return. Further, the barrel, stamped .30-06, is no longer labelled correctly, either. More changes.
Screwing in a new .308 bbl would be the best. But again, a lotta trouble for an experiment.
Wrat
