- Jun 26, 2018
- 1,726
@jlesser27 I think the gearbox should be engaged (1:1) is what I believe he said. I am confused by that (and even what @RJSakowski about using A3 instead of A1) as the gearbox will no longer be connected to the motor or spindle. Almost seems you should put it between gear to where the is zero influence by the drag of the gears.
