Hi folks,
Can anyone recommend a good, readily available grease for the external change gears on the 1236T?
Something that works well (and more than a few minutes!) and doesn't sling all over.
I had tried a red CV grease in the past on another lathe, and that stuff doesn't stick at all. Ends up everywhere but on the gears, including any drive belt. I have some grey Ford moly grease. Not sure if that's appropriate for this use. I have been using, as I saw that recommended elsewhere, some Motul motorcycle chain lube, but I really don't like that. It just seems to turn to glue quickly and needs to be renewed constantly.
Regarding the internal change gears, without adding a pump, do people just try to spray some oil from the bottom to hit the gears on the left side? What a pain.
