I was building a AR15 5.56 and wanted to make my own barrel. I purchased a barrel blank from Green Mountain in 4140 steel, 1:8 twist, 25" long.
I purchased a 5.56 live pilot finisher reamer from PTG.
I needed to have a range rod to setup the barrel. Using 3/16" O1 steel I cut an area for the pilot bushing and threaded it 4-40.
Using the range rod I adjusted the barrel in the 4 jaw and spider until it was perfectly centered. It took quite a while. With the bushing under the aluminum straps in the jaws I adjusted the 4 jaw until the DTI was steady. Moving out to the end of the barrel I adjusted the spider until the DTI was steady. The process was repeated until the DTI no longer moved as the barrel was rotated with the range rod bushing in either position. Note that the range rod only needs to be held in the tailstock drill chuck so only the bushing rotates with the barrel.
Once the barrel was centered I cut the breach end to just clean it up. The barrel was 1" already so I didn't need/want to remove much. D=.980"
The area for the barrel extension was next. .620" long x .850" is the spec. I went a few thousand smaller so the thread profile wasn't so sharp. I'm turning with a left hand tool mounted upside down. The lathe is running reverse so I cut from the shoulder out to the end. Nice and easy, no more than .005" at a time.
