Central Air Conditioning and Serpents; Death by Electrocution
RJSakowski
H-M Supporter - Gold Member
Feb 1, 2015
10,093
Last Thursday night, I abut to head up to bed but it seemed like the A/C was running excessively long. The fan was running but when I went outside to check the compressor, it was not. The first check was the circuit breaker. There are actually two breakers tied with a pin . It was still on but a check for voltage out showed no voltage on one leg. I pulled breakers and replaced the one not working and reinstalled the breakers. The compressor started and it looked like a problem solved but after a few seconds, the fan dropped to a crawl and there was a faint smell of burnt Bakelite so I shut the breaker down and went up to bed.
The next morning, I turned on the breaker but turned up the temperature via the remote access app on my phone so I could restart the A/C while I was there to observe what was happening. I pulled the compressor access panel and immediately saw a problem. There was a dead 10" brown snake hanging from the capacitor with its back section bridging the 240 and the ground through the capacitor body.. I shut the A/C down removed the snake body and restarted the A/C but there was a significant arcing from where the snake had been do I shut the A/C down again.
Removing the capacitor, and inspected it. There was a carbonized path from the fan connection to ground and the insulator/seal on the run terminal was burnt badly enough that the remains simply fell out. Good to see the root cause of the problem bu I wasn't sure that the short didn't damage either the compressor or the fan motor. If it was the compressor, I would have to call a certified HVAC person to effect the repair or install a new HVAC unit so needed to verify that further damage hadn't been done.
Snake .JPG ................................................................ Capaciitor .JPG
-------.....The excised snake................................................................and...............................................The destroyed capacitor
The capacitor is actually a dual unit for both the compressor and the fan motor. I had to replace the capacitor five years previously as the fan section had failed then. At that time, I found a capacitor to sub in which worked until a new capacitor arrived. I spent about an hour and a half looking for a good sub for the 35/5 mfd 370 volt capacitor without much success. I did find a 6 mfd oil filled which would work for the run section but no luck for a 35 mfd. I have a bunch of 12 mfd polyester capacitors so I wired three in parallel for 36 mfd. Kludgy but the alternative was enduring several days of July heat without A/C.
I connected the two capacitors and fired up the unit only to find that the fan wasn't operational. pulled the fan and checked it outside the unit on a 120 volt line. The fa was working albeit at a slow speed due to the fact that it was running on half voltage so I reinstalled it I then realized that the OEM capacitor had a common terminal for the 240 volt leg of the motors and the circuit was broken because of now two separate capacitors. I made up a bridge wire and connected it but had failed to reconnect a wire I had pulled previously. Doh!:bang head:
I corrected the oversight and fired up the unit. It was now working. I checked to make sure that I was getting cold air and I was so I tidied everything up and secured the temporary capacitors with some zip ties and closed the cabinet up. I then placed an order for a proper replacement which should be here Monday or Tuesday. What was potentially a minimum $300 -400 service call and a most likely wait until Monday or Tuesday for a repair was accomplished in a few hours and a cost of $35.
Poor snake. Some creatures can detect AC fields but I guess yours wasn't one of them. Or maybe he was just heading for bed himself
and was going to check for AC fields in the morning...
There is no voltage present when the A/C is off. Undoubtedly, the snake crawled up when the circuit was dead. When it activated, it was too late. Considering the part of the body that created the short, death was most likely not instant. Like some kind of medieval torture device. Apparently the snake hadn't read the high voltage warning on the cabinet.
Poor bugger! I like snakes, around here they eat a lot of bugs and small vermin. (Of course, none of ours are venomous, so it's easy to like them...)
We have a pool pump, that generates a little heat. Nearly every year, we have a few red belly snakes (these are the size of a pencil full grown) take up residence under the motor where it's warm. Trying to maintain the pump, we have to move them safely out of the way so they don't get hurt. One little guy last year wouldn't stay away. Move him, and he'd be back in immediately. Just didn't want to leave his cozy little home.
All this happened after a 400 miles drive back from seeing dad and was getting dark on the Sunday.
I ran through the same issues of no start. At first I was confused as the 24v signal was not present, turned out the 24VAC transformer in the furnace had died. Replaced the transformer with a one from another project. Once that was done, I was back to the ac unit on Monday. I pulled the cap as it is usually what fails first. Motor shop tested it and said it was good. Checked the contactor and it was full of ants. No idea why. Pulled it, filed the contacts and tested. Stilled worked, 20 year old, but went back to the shop and bought a replacement. $25.
Pierre
Pierre
I've heard of this before, particularly with fire ants. One wanders in and fries, the smell brings the others running in defense. Next thing you know the box is full of dead ants.
For some reason the fire ants around here like electric boxes, switches etc.
Pressure switch at water well is attached about once a year. A/C system not so often but more than I like. I guess cause they are both close to the ground.
Did find a lizard fried on a capacitor on A/C once.
Chuck
