You did a nice job on the '54! I like it!
-Bear
Thanks. Nice work on your '51. I'm impressed. Here are a few more pix of my '54 in progress. In addition to sealing up cowl vents/side vents/etc., we made some not-so-obvious changes that make it a little more of a pleasure to drive.
1. Here's a shot of the drive train before reassembling the body. Again: 4.3V6 with 700R4 automatic overdrive. If you look carefully, you can identify the Firebird front-end clip and rear-end assembly. (That's my '55 off to the side.)
2. This a little subtle, but notice there are no vent windows. (A little hard to tell in the photo.) Chevrolet made this body style from '47-early '55, but for some unknown reason, they did not include vent windows in one year model ('49, I think). I liked the cleaner look without the vents, so I simply converted over to the windows for that year model.
3. Back-up lights. Back in the '50's back-up lights were optional or just not available on many pickups, so I modified a pair of '47 truck parking lights to fit below the tailgate. Those are dual element bulbs, so both are wired to give a fairly bright back-up light.
4. Relocation of fuel tank. IMO, this is one of the two most significant changes I made. I never liked the idea of the fuel tank in the cab. After much studying, I purchased a universal fuel tank and fabricated mounting brackets to put it under the truck (essentially where a spare tire would be on newer trucks). I also went to my local muffler guy and got some scrap pieces of tail pipe and welded them to the approximate size and shape I wanted the filler assembly to be. Took that contraption back to him and, together we bent the size and shape we needed from new tail pipe. The filler neck and cap are from the original tank, and the bezel was machined from a steering wheel bezel. (P.S.: Watching a machinist mill that bezel is what gave me the interest I developed in machining. Glad he let me watch!)
5. Metal bed. This is the OTHER can't-do-without modification. Wood beds are nice - if you're a purist and/or you want to show the vehicle. But if you want it to be more functional, a metal bed is far more preferable. The downside is that most conversions use a piece of thin sheet metal or diamond plate that just plain doesn't look good. I took some measurements and found that the bed out of any relatively late model FORD (yes, you read that right) short bed pickup fits the dimensions of the Chevy almost perfectly - dead-on lengthwise and about 1/4" narrow on the width. I went to a junkyard and bought a candidate and we welded it into the floor. It turned out very nice and pretty much looks factory.
Sorry to be so long winded. At the stage you're at in your rebuild, it occurred to me some of this might be food for thought for you.
Regards,
Terry
