- Oct 28, 2020
- 543
The bearing and bearing housing mounts to the end of the auger with four bolts in a square pattern. Your right it should be mounted with bearing split horizontal.Is there a reason the split line of the bearing is vertical? I would think having the load zone out of the split area would give it more life, and would be easier to install in that orientation.
Hah, yeah, I also was amused by this. He did a great job getting a superb surface finish (and probably a bunch of time making sure he hit his dimension right-on), just to have the bearings be rough castings.Nice work. It seems a bit strange that your beautifully machined bores mate with as-cast iron bearings.
