Tom,
I use an Hornady Ammo Factory which is a fully automatic press with Auto Case, Primer, Power and Bullet feed. The point I am making is the case on headless ammo is tapered from the head to the bullet end. The dies I use are full length sizing dies that size to that specified taper.
I am trying to understand how a passthrough die can maintain that taper. Are you sizing to the upper end of the taper to take out any head swell in the case?
I know that if I don't maintain that taper the case will either seat too high in the barrel and not chamber or too low and the firing pin will not strike the primer. I use a Reddiing Go No-Go gage to check see that the taper is correct and that the loaded bullet will chamber correctly.
I am firing in Kimber Custom pistols.
I load 380, 9MM Lugar, 40 cal and 45ACP plus al lot of others which are either straight cases with a head like 357 mag and a lots of bottle neck rifle sizes.
Dennis
