No, no, not my pages. Just something that a web search led me to. The main page says "Copyright 1998-2012 Dean Williams".great projects on your page craig.
inspiring to a noobie.
I'd very much like to see more details.
Craig
Looking good! The multi-part construction explains some of the 'extra' screw heads!Just remember as hobbyists, we may have more time than money, and often just scrap lying around. I made mine out of two pieces since I didn't have a piece large enough. I have tonnes of fasteners so often fabricate stuff from multiple pieces rather than one larger on. This is also useful if you don't have a mill. You can cut shapes from two pieces with a hacksaw and join the pieces eliminating the need for a mill.
Here are close ups of mine. I wanted the tightening cap to be above or easy access so added a brass piece to protect the ways from the screw.
View attachment 284971View attachment 284972View attachment 284973
David
Well, I guess you can make up for your boo-boo by sending me your stop! jkThe other thing is that you can also set the indicator to 0 at the same place as the carriage stop. This way you can see if the stop is moving.
EDIT:
Folks this is not correct! Since the dial indicator and the stop rod are in the same block if the block moves so does the indicator, so movement will NOT be detected on the dial.
However if the stop rod is not secured in the block and it moves but the block stays stationary on the ways then this condition will be recorded on the dial.
Woke up this morning and expected to be flamed by my original statement.
