Thanks Rich, that's good advice.
Also wish to mention that interrupted cuts put a quick end to carbide. Also, the 1st passes on a piece of rusty/scaly stock chips the surface too. I've gotten into the habit of sandblasting first and also using cheap HarborFreight brazed carbides to remove scale. They're good for several descalings and can be touched-up with a wheel. -And for 50 cents a piece, it's no great loss if one chips deeply.
Ray
Ray
One more thing, you guys probably know this, but will add for the beginners. Be sure not to stop the spindle when the carbide is engaged in the metal as it will crack or chip the carbide. Make your pass and move it back or screw the tool back. Even dragging the tool over a stopped part will damage the cutting edge. I would also suggest you look at a Glendo Grinder for sharpening the tools, slow speed and no heat. I have one I have used for 20+ years and only replaced the 600 grit wheel 3 times, but I also use it in my scraping classes. For an occasional user a wheel would last for years.
