- Feb 2, 2019
- 139
Thanks,With the grain or cross grain? It will make the cut. How straight I don’t know? Not sure what you are attempting? Bandsaw would work better if you have access to one. Ipe is fairly hard to work with. Sharp tools are a must.
Cheers
Martin
Thanks,Carbide does not seem the appropriate choice for LPE. A good sharp, coarse pitch blade intended for wood will probably work better. Keeping blade speed slow to avoid melting is important.
Don't bother with a Sawzall, a hand held circular saw will do. Use a 24 TPI or less blade and cut to 2-1/4" deep using a fence. Lacking a fence , make a jig with 1/4" plywood the length of the saw base and 3" wider. Drill 4 holes in the saw base for screws and nuts. Attach the plywood with the screws .Hi Everyone,
I need to make one straight cut into a Ipe 4” by 4” by 12’ piece.
Will a super sawzall (cordless) with EZARC Carbide tipped blades 9” long with
3 tpi cut it, or am I wasting my time ?
Thanks again,
J
ThanksDon't bother with a Sawzall, a hand held circular saw will do. Use a 24 TPI or less blade and cut to 2-1/4" deep using a fence. Lacking a fence , make a jig with 1/4" plywood the length of the saw base and 3" wider. Drill 4 holes in the saw base for screws and nuts. Attach the plywood with the screws .
Screw or bolt a scrap 1x for a straight edge that will give you a 2" cut. Make cut, flip over and saw the rest with the straight edge against the same side as the first saw cut. This should give you a decent pair of 2x2x12' boards. I have worked with Ipe only twice . I recall it was difficult to drill, not sure about ripping or crosscutting as this was 15+ years ago. The fellow I was working with carried a bunch of cut offs to a trashcan when 1 piece fell off. The 10" 2x6 sunk right to the bottom of a kids pool. We were amazed, tried a small piece about 3"x 6" and it sank too.
mike
