I will keep this as short as possible, I got a 2.5" face mill that takes SEHT inserts and I can't seem to keep them cutting nice. I got the face mill used with my mill, and the inserts that where in it seemed to not cut worth the poop, so being used I figured the previous guy probably got all the sides dull on them so I ordered some Kenametal SEHT 43A6 inserts (from my very limited experience with carbide my research said they should work good). Put these new inserts in yesterday and while facing off a piece of mild steel, doing 270RPM (the slowest my mill goes), .005 depth of cut, the inserts lasted maybe 5 minutes before the chips turned into dust. So I turned all the inserts to finishes my job, and again maybe 5 mins the chips started to turn into dust. What the heck is going on here? What am I doing to cause these inserts to dull so fast? How long should they last for? 5 mins seems awful low. If it matters there is 4 inserts on the mill. Are they the wrong inserts? Thanks everyone!
