Carbide insert and holder help needed.
sundown57
Aug 10, 2021
179
I was talking to a real machinist about carbide inserts and he said to get started just buy a cnmg with a negative rake. that way you can 8 pieces out of a single insert. well when i do a search i can't seem to find a square one that can be flipped. could any one help me figure out what insert and holder he was suggesting ? thanks
I have an Enco 16x40 and a massive old Clausing thats like 18x60
ok, those will do it.
So to get 8 cutting edges out of a cnmg, you need 2 holders, a normal one and one to hold it 90 from the normal so it can do chamfers and what not.
The cnmg is not square. It's a rohmbus
So therefore the need for a 2nd holder to use the side that's not normally used.
So for normal cutting you'll get 4 edges, then with the 2nd holder 4 more.
do they make a true square insert that can be flipped ? maybe i didn't get the letters right.
I think the machinist means a SNMG insert. That has 8 identical cutting edges. Because these inserts are targeting larger lathe's you have to take heavy cuts to get the chip breaker working. Not an insert for making small stuff. Also when you chip an edge, the bottom edge could also be ruined. To safe money, you have to calculate the price per cutting edge.
Because of the 90° cutting edge (no clearance), this insert is nut suitable to cut up to a shoulder. A WNMG insert has 6 identical cutting edges and a °5 degrees clearance.
looks like the WNMG would be a better choice for me. Plus i see i can buy it as a set with the holder. thanks
Number of cutting edges is more of a factor in production machining, otherwise I would stick with CNMG, WNMG, DNMG type inserts. CNMG type there are alternate holders to use additional edges, but is it really worth it.
I cant understand why NO company that sells inserts put the number to the holder that goes with it.
Most inserts can be used with different holders. If you google the insert type, you will find suitable holders.
If you have a mill, you could make the holder your self. It takes time to do so but it is not a difficult project. If you have a CNC mill, than it even isn't time consuming.
I make most holders my self so they fit my needs and tool post.
