- Jan 25, 2022
- 129
Continuing my new lathe education: Thought I try boring a deep hole in my sacrificial brass rod. Don't have a boring bar with HSS, but one with carbide insert with those molded-in chip breakers. Thought I'd try it, not expecting great results.
First drilled out to 0.5", about 1.75" deep, then bored to ~0.69". Didn't want to go larger as the walls were getting thin.
I was surprised at the results, thinking that tool geometry vs. brass would be a problem. Good finish all the way in (didn't check ID all the way in, however).
The carbide bit is rotated down about 20 degrees. Maybe that helped?
