- Jan 5, 2023
- 14
Hi Everyone!
I'm new to the forum and this is my first post. I'm in the market for a PM bench mill and it would be great to get some feedback from the experienced machinists out there. I've been primarily working with wood for the last 15 years, but find myself greatly limited (using existing equipment), when it comes to making a few basic metal parts. It's time to throw a truly dedicated metal fabricating machine into the mix.
I'm a HOBBYIST ONLY, needing to fit the machine in an already crowded (woodworking machines) two car garage, for small hobby projects. Typical usage/needs would be the following:
1) Parts/Month: 2 or 3 on average
2) Material Used: 80% aluminum, 20% stainless steel (all my parts have to be corrosion resistant)
3) Dimensions: 95% of parts fall within a 10 x 10 x 1 inch footprint
4) Operations: Edge milling (1/2” dia tool max), Face milling (0.080”/pass depth, 2” dia/pass width would be fine), Pocketing (1” deep in alum, 1/4” deep in SS), Drilling (thru 2” alum, 1/2” SS), Slot Grooving (0-90 deg in X&Y is a must).
5) Accuracy: +/- 0.005” (Stop laughing … I'm a woodworker!)
Side note: Icing on the cake, but don't necessarily need, boring and tapping.
I've done quite a bit of research now and keep coming back to the same conclusion. Everyone and their brother says don't mess around – get a knee mill. Although I can clearly see that pricing of a used Bridgeport is similar or less than a new Precision Matthews bench mill, I really don't think I need that big of a machine for what I want to do and where I want to put it. I don't have a lot of young male buddies around either, making me dread the thought of having to get (and stuff) a 1000+ lb machine into my garage and assemble it. Although I want to purchase a machine that allows me to grow a little bit, I definitely don't see myself cranking out the volume or complexity of parts that a knee mill is capable of. I have no intention of going CNC either. I'm in my 50's and prefer the old fashion manual methods of doing things. I also have no problem going slow in getting a job done, I just don't want to prematurely wear/degrade the machine or tooling due to pushing either of them beyond designed capabilities.
My gut feeling is that a nice Taiwanese made PM bench mill is the way to go. (If there were a quality, American-made machine in this size, I'd jump on it!) At first, I thought a PM-728VT would be a fine choice, but then realized that a PM-833TV significantly improves on it in almost every category for only $1k more. So that's where I've landed. Is this a good choice for my needs, especially given the occasional SS part and space/weight limitations? I figured I'd start out with the base model, plus Z power feed, bringing me to a grand total of $6k including tax and shipping. Again, from what I've been reading, this is where most simply scoff and point out that for this kind of money, I could easily get a nice used American made Bridgeport – which is absolutely true – but I don't want anything that BIG and HEAVY! Your words of wisdom in helping me choose a best fit PM mill (1Hp? 2Hp?) would be greatly appreciated.
Thank you!
Thank you!
