completed the welding table (I think)
the top angles are spot welded in place so they can be moved
the only piece not angle are 2 bottom supports which are steel tubes from a curling bar (I use olympic bars for lifting now so didn't need it)
also ground all corners round on outside where you might hit them and cut off all overhang
I'm wondering how long it will take to rust thru if I leave it outside
next project is to turn that dolly in the picture into a real welding cart by putting braces around the FCAW and making a holder bracket above it for miscillaneous stuff
