I never liked mig but I got one yesterday, although I think it's not a true mig but rather a 90amp flux wire welder from good old central machinery in chicago. Guess there must be a chicago in china.
So it's a long story why I got one b/c I was looking on CL to get a stick or inverter and found a deal I couldn't pass up, meaning for $30 I could get a HF helmet (which I needed) AND this flux wire welder and extra wire that came with it.
So I cleaned the tip and the spool turns OK but the place the wire goes right before it enters the cable (I don't have instructions so I don't know what it's called), has a thumb tightening wheel and when it turns, I notice it just spins against the wire.
I tried tightening and loosening it and it still spins, just occasionally griping the wire for a micro-second to feed out a tiny bit of wire. I also tried different wire feeds and faster just causes it to spin and slip faster.
Anyone with advice appreciate.
(the other problem is it's hard to see what I'm doing with the helmet, even when set on lowest 9 reading. I did some test welds, but had to pull wire out with pliers)
