- Nov 6, 2012
- 157
My 5" brass mini-cannon build, done on a SouthBend at our Makerspace, is a bit more challenging on my home 7x16 mini-lathe. I chucked a 7" 1-1/4" 360 brass rod in my 4-jaw chuck, set up a steady rest 2-1/4" from the end, and turned down the 0.9000" dia 1.8" long breach section. On the big lathe, our retired professional machinist shop instructor did the curved tapers by hand for us, turning both axes simultaneously. We practiced a bit but us newbies didn't have "the touch" yet. I'm looking for alternatives, given my minimal experience.
I figure I can cut that 0.16" wide 0.63" dia narrow "waist" depth with a cut-off blade, then file the back of the button-end down. I'm thinking to approximate the tapers by angling my compound rest to progressively cut angles and rounding with a file.
Advice appreciated! Again, it's a 7x16 mini-lathe and, while I appreciate thoughts on interesting tooling/fixtures I could make, I'm wondering what I can do with what little I've got already. I'll add those tools/fixtures I can make to the list.
