A while back, I heard antisieze was abrasive too so I looked into it. Antisieze is typically made from two components, a grease and a solid lubricant. The idea is that the grease prevents sticking below 400 degrees but if temps rise above that then the solid components, typically copper or aluminum, step in to prevent sticking/galling. The compounds with copper and aluminum "may be" abrasive; I couldn't find an article to support this claim. To get around the possibility they make antisieze without metallic or carbon (graphite) solid components that are non-abrasive when broken down.
The bottom line is that not all antisieze has abrasion potential but to my knowledge it also does not have load bearing capacity (the grease melts out at 400 degrees) to be used as a lube for a dead center.
So, good thought Toz, but no go.
