- Dec 20, 2012
- 9,422
I have a parting tool and parting tool holder, but it won't stick in my QCTP well. I got the blade at least. I just need to find a way for it to stay in the QCTP and stay parallel to the chuck.
You can grind parting tools from square blanks but it is a lot of work. You need about 5 degrees of relief on both sides and 5-10 degrees of front relief. Best way is to rough it out with a tool grinder and then use a fixture to accurately grind the side relief with a surface grinder. Assuming you don't have the equipment to do this, using the parting tool you say you have is probably the best bet.
I am unclear as to what you mean by "... it won't stick in my QCTP well." Perhaps you can clarify what kind of tool you have and what your problem is in more detail. Seems to me that sorting this one out will be easier than grinding a tool from a blank.
Just an aside but if you are not using a P-type parting blade, you should try it. I use a P1-N mounted upside down in a rear mounted parting tool holder on my Sherline lathe to part stock up to 2" OD at high speeds with no chatter or dig ins. This P1-N blade is only 0.040" thick and I've never broken or bent one. It has parted everything from Delrin to 4140 to O-1 steel without a whimper. I use a P1 or P2 on my larger Emco lathe and part from the front, again without issues, so I happen to favor these kinds of blades. I also have an Aloris inserted carbide parting tool that works well but it has a 1/8" thick insert - wastes a lot of material.
