Can you make a parting tool using HSS blanks?
Pcmaker
Jun 12, 2018
724
I don't have a parting tool, but I have some 1/4" blanks. These specific ones:
https://www.amazon.com/gp/product/B0131IRHLM/ref=oh_aui_detailpage_o06_s00?ie=UTF8&psc=1
Can you make a parting tool using one of these? I figure it's hard because it's gotta be absolutely parallel.
Also, my carriage is smooth to turn on the chuck side and as I move towards the tailstock, it gets tougher to turn the carriage wheel. Any tips? I've played with the bolts holding the carriage wheel, but can never get it right. That and as I adjust the bolts, I gotta keep in mind the thread dial indicator to keep it working.
First off, wow that's expensive for plain old 1/4" HSS, those should be no more than perhaps $2 each. I would check with Shars, CDCO, or the usual suspects in the future.
As for the utility, I don't see any reason you *can't* use one. You will need to grind relief angles on the nose and the sides, but otherwise it should work OK. The only real disadvantage as I see it is you'll lose 1/4" of material with every parting cut...which may or may not matter to you.
I meant grinding it down to where it's thinner. Maybe to 1/16th of an inch. The problem is getting to 1/16 and having it perfectly cut.
You can absolutely do that -- it's the only type of parting/grooving tool I use.
You are limited somewhat to the depth though. After about 5/8" or so it gets hard to keep things consistent in the grind, but up to that is pretty easy. The trick is not to keep it parallel, but to make the top edge slightly wider and also keep the leading end slightly thicker. That way there is no drag on the sides. I'm not talking much here -- a couple of degrees if that. I use a grinding wheel and rest, I would not recommend trying to do it "freehand" although I suppose it could be done.
Mine is presently ground out of 5/16" square HSS, and the width is about 0.068" ( so just around 1/16" thick). Not the greatest photo, but here it is being used
image-jpeg.270814
-frank
This is from a rookie, but I was struggling with a job needing parted. My parting tool was flexing like crazy. I happened to have such a ground tool in my box of goodies, and it worked great when I tried it. But yes, it's limited as to depth of cut.
As for the difference of movement, could it be wear of the bed/ways when closer to the headstock since it sees more use over there?
Obviously, the thing to do is buy a real parting tool and holder; if you intend to part off small delicate things in soft metals, you may get away with 1/16" wide tools, but bear in mind that they WILL break easily, and will tend to wander sideways in the cut, and not cut off squarely. Better use a minimum 3/32" wide tool, of the standard type, or even "T" type, but they will also wander if the cut is very deep. A 1/4" tool bit would have very little strength in the vertical plane, especially when ground on the sides to a narrow width, with tapered clearance vertically, and consequently break easily. Typically, small lathes do not seem to be particularly good at parting in the first place, even with proper tools.
One thing that I have noticed is that especially when using a QCTP, if the post is not positioned towards the center of the cross slide, instead of overhanging the cross slide, as they are often positioned, the holder with the parting tool tends to tip towards the chuck, putting the parting tool into a bind that can cause breakage of the tool.
I have a parting tool and parting tool holder, but it won't stick in my QCTP well. I got the blade at least. I just need to find a way for it to stay in the QCTP and stay parallel to the chuck.
How else would you grind it down with a benchgrinder,if not free hand, though?
Some people use the rest for supporting the hands and hold the tool being ground higher up on the wheel. That's what I was referring to as "freehand", as opposed to resting the tool solidly on the rest while grinding.
-frank
  • Like
Reactions: Z2V
A parting tool holder for your QCTP is around $20 from Shars. Good parting cutter blanks are around $5 in various thicknesses and tool steels. Much easier to work with, even though a ground square blank will do the job in many cases.
