- Sep 29, 2017
- 2,307
Thanks gents,for all the advice, but I must give credit to Mr. Whoopi because I went with his DRO 360hole idea and it worked quite well. I knew I could use the bolt circle function but did not think of using 360 holes as the number of holes, so thank you Mr.Whoopi for pointing me in the right direction. The mistake I made was trying to drill holes on an arc I made with the calliper and I was bit out so the slot looks a bit rough and out of alignment with the arc on one side, bit it will work for the requirement. I still need to do the bottom plate and tgen I will get it right.
An arc has been made......it won't float but it will let a bolt slide
The pic below shows the rough side on the one side.
Thanks everyone.
Michael
Thanks everyone.
Michael
