Despite having only one axis of my DRO installed on my mill i'm already pondering how to add a fourth on the quill to get the summing function using TouchDro. So the question is this:
Can you cut the armored cable of a MagnaSlim read head and splice a ribbon connector onto the lines? Then put a new DB9 connector on the armored cable and connect to the F DB9? Anyone done anything similar?
Using the MagnaSlim scale and head it looks to me like i can fit the entire thing inside my PM833 head behind the cover plate. The ribbon wire/connector is needed for flexibility inside the head. Outside the head it would be the newly spliced armored cable end and a guide rod attached to the quill (no scale or read head exposed). This would add a removable connector and a splice to the read head system, but i don't see why it should not work - but i also don't want to chop a calibrated wire or something.
this is the type of ribbon tape im thinking of
