So i have spent lots of time trying to bridge the knowledge gap. I can say with about 90% confidence that I know know how an AC induction motor works. What use to be PFM is now knowledge. This video was the AH HA! moment for me. It deals with 3 phase motors but it made it much clearer. The same gentlemen has a video on single phase motors that build off of this video. In conjunction, they made it seem easy.
I then found this video which helped some. It is by the same creator and builds off of the knowledge above and makes it seem easy.
In this video he discusses a method to use a mulitmeter to determine which winding is a running and which is the start winding. In its most simplistic form, the winding with the highest resistance is the start winding because it (most typically) uses a lighter gauge wire for its winding being as it is not in continuous use. Using this concept I set out with my trusty (now 20 year old) Fluke and got to work. I have 6 total wires in the junction box. 1 through 4 are gray and 5 and 6 are black. My multimeter does not test capacitance. Quick amazon order later, I have one on the way that will. This means that the capacitor is still untested. However, it started fine with I test ran it so that is not a priority. I do know however that wires 5 and 6 are the wires that bridge across the capacitor. I checked for continuity across those leads after ensuring the capacitor was safely discharged and the removed. I know that leads 1 and 2 are low resistance as well as 3 and 4. Both pairs reading less than 1 ohm (I think, Auto ranging might be getting me here). I hade no resistance across just 5 or 6 and had more than 1 but less than 2 across 5 and 6 with the capacitor in place.
A photo of the capacitor for reference.
With knowledge comes more questions. Does 5 and 6 represent the start winding? Is the capacitor giving me false information here?
I did further test continuity across the other lead (1-3-4, 2-3-4, 3-1-2, 1-5-6, 3-5-6) and got none across those. I also read somewhere that capacitor can be polar or have a polarity. Mine had no markings as such.
To add to this puzzle I have another machine, long story don’t ask unless you want to give it a good home, that had a very similar motor. It is a 4 pole single phase dual voltage 1720 RPM but it is 3 HP. I mention this because it has a fwd/rev switch already wired in that I can peak at to help wrap my mind around the physical application compared to the theoretical.
Now, as I understand it, if I feed the start winding from the other side it will change the rotation. Please insert corrections here. As a more practical application, if I swap leads in 5 and 6 in the wiring diagram then that should change the direction of rotation. Correct? Insert more corrections here. That leads me to a problem with my specific application in that I have 4 terminal bars in the motor junction and 3 are used. Further more the brass bars are molded into the unit and not removable. How would I wire the motor in this application? When I say how would I wire it, I mean all the way back to the 4 line wires coming in. I understand that it would be 3 line (2 hot 1 neutral) and then the green ground. The green ground gets bounded to the box at each of the stops along the way (drum switch and then motor casing). With the other 3 (black red and white) carrying the current. How many terminals on the drum switch? I have seen 8 12 and 16 terminal variations, with my thought being an 8 terminal being correct for this application.
What are the errors of my ways? If I have to change windings or go beyond the changing of some wire’s in the junction box, I would rather spend the money and look seriously at 3 phase and VFD. I get little time and want to progress as I mentioned in the original post. If I can make a few wiring changes, let do it.
@RJSakowski I saw your article before I had full grasp on how things work and it seemed more than I could chew on both in terms of skill set and mental capacity. Might be different now but you are much braver than I am at this point.
@Eddyde The video you posted is good but it did not speak to me like the others I posted I have however watched it.
@Ulma Doctor You sir have been a help. I watched your videos on the lubrication of your Shen Wei lathe which happens to be a be fundamentally the same as my Lantaine LAM 350B 10x24 lathe. It was a good guide to maintaining my machine once I get here QCGB back together so that I can try and get that machine running. I thought I had it all lined up last week but the thrust bearing I ordered were wrong so I am waiting those to finalize that. I am guessing that your post about he SSR switch would answer the drum switch question from above. I will try to look at that when I get a minute.
Thank you to everyone has replied and anyone that will reply to this post. I however go back to work tomorrow and don’t get more than 24 hours off at any one time April 1st. My day job is running around on the ambulance causing trouble so I swing back into that shift work staring tomorrow and will not be able to get much productive time in the garage or keeping track of progress here. Just don't want anyone to think I abandoned the topic or lost interest. As Arnold would say “I’ll be back.”
