Cam lock spindle issues
[Addenda] b To use a D-x spindle it has to lock strongly enough that when you want to remove the chuck, it takes a sharp 'rap' from a soft or deadblow hammer to 'knock it off' the taper. If the chuck doesn't lock onto the taper with the cams undone, there is something very wrong.
Hey Dabbler,
Do you know where i can get parts for this machine? Its missing a few things and the grizzly parts i got look right, but are not the same.
The shaft and 15t gear that runs the carriage feed was missing when i got the lathe. I was able to make the other things i needed with my mill.
I cant find a clear picture of what the shaft looks like either.
